Parallella Community • View topic - Epiphany - Double alignment issue
Postby heshamelmatary » Wed Nov 26, 2014 9:12 am
I got some undesired behaviour with the compiler's generated code. It's said in the manual that structures and double words should be aligned to 8 bytes. I am makinh sure that the start if the stack is aligned to 8 bytes. Given that, some structures created within a function are not aligned to double-words, and subsequent read/write (which uses strd and ldrd instructions) accesses causes an exception to occur and hence the program hangs. Is there a compiler flag to force such a problem? Most of the flags like -malign-double -m64 are machine dependent (x86, sparc).
Hesham
-- Hesham
heshamelmatary
Re: Epiphany - Double alignment issue
Postby heshamelmatary » Wed Nov 26, 2014 6:05 pm
Digging into more details, the exact assembly store instruction that hangs the program is
ldrd r0,[fp,+0xc]
strd r0,[sp,+0xa] ;; here where it hangs
sp = 0x8effff04
fp = 0x8effff04
r0 = 0x0
Why fp is not aligned to 8 bytes? Given that the initial stack and fp address is "0x8EFFFF00" set at the linker script.
Some structures are not double-aligned when generated too, where I have to add __attribute__ ((align(8)));
Last edited by heshamelmatary on Thu Nov 27, 2014 1:08 pm, edited 1 time in total.
-- Hesham
heshamelmatary
Postby notzed » Thu Nov 27, 2014 2:55 am
Shouldn't the linker script setting up an 8-byte aligned stack to start with? The ABI requires that the stack is always 8-byte aligned so the compiler doesn't have to ever waste code aligning it.
Postby heshamelmatary » Thu Nov 27, 2014 9:34 am
-- Hesham
heshamelmatary
Postby notzed » Thu Nov 27, 2014 11:46 am
You should provide an example and the flags you use.
Postby heshamelmatary » Thu Nov 27, 2014 12:15 pm
-- Hesham
heshamelmatary
