Parallella Community • View topic - atomic operations
atomic operations
atomic operations
Postby dobkeratops » Sun Jun 07, 2015 10:58 pm
Can the epiphany cores do atomic operations on main memory. I recall using these on the CELL processor to help with SPU's collaborating (e.g. a SPU's could update an atomic counter for the next job index .. be that input or output. think of operations where the number of outputs is variable, and you want to accumulate a collection)
If it can't - what are the workarounds.
example use cases: parallellized for_each (several cores consult a single atomic counter for the 'next' index to process); and accumulating collision results (e.g. comparing a list of objects against itself, emitting a list of contact points which is variable - use an atomic counter for the 'output index')
dobkeratops
Re: atomic operations
Postby sebraa » Mon Jun 08, 2015 1:07 pm
What do you mean by "main memory"?
Any aligned 32- or 64-bit write is atomic due to the way the mesh works.
To implement locking, the architecture supports an atomic TESTSET instruction, which works inside one Epiphany chip only. Across chip borders, you need to implement synchronization on your own.
Postby dobkeratops » Mon Jun 08, 2015 3:41 pm
dobkeratops
Postby sebraa » Tue Jun 09, 2015 5:14 pm
Postby dobkeratops » Tue Jun 09, 2015 6:23 pm
dobkeratops
Postby sebraa » Tue Jun 09, 2015 7:09 pm
Postby dobkeratops » Wed Jun 10, 2015 5:50 am
dobkeratops
Postby aolofsson » Wed Jun 10, 2015 1:45 pm
Postby piotr5 » Wed Jun 10, 2015 10:00 pm
piotr5
