Parallella Community • View topic - Cannot boot after update FPGA .bin file
Postby jimmystone » Thu Aug 18, 2016 2:51 am
jimmystone
Re: Cannot boot after update FPGA .bin file
Postby jar » Thu Aug 18, 2016 6:51 pm
I've seen the situation where I installed a new image and was able to ping but not ssh into the board. Rebooting didn't help. My solution was to write the image to the board again, plug it in, wait a few minutes, and try to ssh again. It then happened to work. I think there is some setup during the first boot up that has to occur. If it's interrupted on the first boot, it may not work. I'm only speculating. Maybe Ola can provide a better answer.
Postby jimmystone » Sat Aug 20, 2016 3:08 am
jimmystone
Postby thickglass » Mon Nov 28, 2016 7:39 pm
Got the same problem, thank you
thickglass
Postby aolofsson » Mon Nov 28, 2016 11:26 pm
You might be missing a step in the bit.bin header. See the following for guidance.
https://github.com/parallella/oh/tree/m ... lella/fpga
Postby sebraa » Tue Nov 29, 2016 10:01 am
If the Linux driver for the eLink loads, but the FPGA logic doesn't work correctly, the system will crash early (after getting an IP, responding to a few pings, but before being able to SSH in). You can try to disable the elink device in the device-tree to prevent the driver from loading.
