Cyclic timer
Cyclic timer
Postby SKyd3R » Fri Aug 02, 2019 10:59 am
Hello there!
I'm developing an open source operative system for the Epiphany III and I'm needing a cyclic timer that set the timer counts once the timer reach the 0 value.
At the moment the interrupt handler is resetting the value but this is missing some cycles and it is problematic if another interrupt is being handled.
Is there anyway to set the timer in a way it resets by itself?
Greetings!
SKyd3R
Re: Cyclic timer
Postby jar » Wed Aug 07, 2019 9:34 pm
Not with Epiphany III.
Your interrupt routine could start at a value 0xffffffff minus the number of clock cycles for timer interrupt reset. Your other interrupts could potentially stall and/or reset the timer if it's near 0.
Re: Cyclic timer
Postby SKyd3R » Thu Sep 05, 2019 9:51 am
Thank you.
That's the kind of solution I made.
SKyd3R
